Does it require earthing?
It’s not an exposed-conductive part as it’s under the clear sheath.
It’s no use as a CPC.
I doubt it would function as an earthed metallic sheath if the cable were penetrated by a metallic object.
Good point,Swa as a covered sheath,& not always used as cpc,but is earthed
No I haven't but I can tell you it's a Hager. I won't be going back as after pointing a few things out to the owner he has appointed another electrician to do the report.
in other words he wants a tick-box satisfactory report for peanuts. yous best off out of there.
Exactly, thanks for confirming my initial thoughts
Reactions: suffolkspark
20p : Containment - when the lid is down is the IP rating achieved? Can the lid be secured so that a tool is needed to open it? If not, then seeing a bit of exposed copper makes me go for my C2 bat. Am I too harsh?
Swansea
Business Name
Michael Jones Electrical Inspection
What do you code these? Commercial installation
Michael J,
Deleted member 26818,
