hi aver1 i normaly use wylex boards ,but its to expensive ,thinking of useing BG ,ADVICE PLS
wylex 10way board WITH 8 breakers £56 plus vat BG 10way with 10breakers £ 41 PLUS VAT
iv fitted this board and if im being honest i found it as good if not better than the bigger name outs there! would almost certainly use them again..
same here. decent board. only gripe is the internal tails take up a lot of space.
agree with Tel I used a couple now and find them ok be careful with terminal screws as a bit soft but I always a little heavy handed so it may jsut be me
I would deffo use them again which I wouldnt a wylex again by choice
Fitted one on sunday, nice and easy to cut out access points, even on the back, fixing points in sane locations and nice and sturdy when fixed. RCD and RCBOs tested out well within trip times (I5n - 28ms and 31ms on the RCBOs and 11ms on the RCD itself)
Know what Tel means about the internal tails though...too long IMHO and twisted slightly odd directions from the factory. Right angled ferrules would go a long long way to making things better and neater internally...
Cover easy enough to reattach securely...unlike some wylex and mk boards...also quarter turn, so quick and simple to remove.
I like them...and plan to use them again in the future.
The cheap boards probably have the same Rcds and Mcbs as the more expensive,but why oh why do they secure the covers with those half turn plastic contraptions
If they sent a spy into a Crabtree factory,they could steal the technology of that fantastic and clever invention called a metal screw
