Discuss What export options are there currently? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi guys, I can fit 15kwh worth of solar panels on my roof space, and i'm debating if I should either export to off set my electric bills or go off grid.
The roof is on a commercial building but we only have single phase supply.
So is it wothwhile exporting compared to going off grid? what are the current export rates and would I need 3 phase installed?
No it's not worth to export for pathetic 4p per kWh that most suppliers offers. Some does 10-12p but certain criteria needs to be meet, like owning EV. Depend how you use your energy it may be better to install less panels and invest in battery storage to maximise usage of generated energy. Either way 3ph is not needed. Proper calculation would be essential to determine which option is best, ie. on grid battery storage or off grid with generator etc
Also best to ask as AFAIK if you have more than 3.7kW (16A) there are extra restrictions, etc, on the system and to what you get in payment.
Reply to What export options are there currently? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
My best mate has been medically retired from the prison service at the young age of 52 and has time on his hands :D He's looking at a 'plug in'...
Hi all I had my PV/Battery setup installed in May and since then all my excess PV is just fed back to the grid for free. When I initially tried...
Hi, I'm new here, having recently had nearly 13kWp of solar panels installed on a barn roof, feeding into two Solis inverters (covering about 10...
8K
Hi, So I'm replacing a small old off grid with a new 7.5kw off grid, & being poor seek best value for my mppt, after long searches I find this...
