Discuss What is an example of functional earth? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Very quick examples are leakage from SMPSU’s as has already been said however anyone old enough to have played around with turntables will also remember earth used as a reference point, and so on.
Also less common are things like static bonding (workshop anti-stat mats are a good example).
Of course another old example is the earth connection to go with an outdoor long-wire aerial for the old valve radios.
CPC's on most final circuits are also used as 'function earths''. Internally in many appliances surge arresters and EMI noise filters use the CPC to sink any current that is produced by their normal functioning resulting in the CPC carrying two types of current, obviously fault currents but also functional leakage currents. In certain installations a separate functional earth is installed as well as the CPC resulting in a 4 wire final circuit, usually in medical installations or low noise installations such as radio stations or music studios or even server rooms/IT type environments.
Here's some other threads on this foum over the years..
A television studio I used to work in had a 'clean earth' supplied to various areas and equipment racks.
Clean earth is not quite the same as a functional earth if I remember corrrectly.
why do I have a funny feeling that a functional earth should be white in colour,? could be wrong here as it is 20 years since i looked into this.
looks like I was wrong, it happens every now and then.
suppose it proves I am human?!!
Looks like I was wrong.
extract from iet
What is functional earth​
Functional earth is the earthing of a point or points in a system or an installation or in equipment for purposes other than safety, such as for proper functioning of electrical equipment.
This is also known as isolated earthing or clean earthing or noiseless earthing or separate earth.
In home wiring it would only be required where there was equipment that required functional earthing for it’s operation. The connection of any functional earthing should be made to the installations Main Earth Terminal and be clearly labelled as to its purpose.
A functional earth, if it is just a functional earth and not in any way protective conductor should be white or cream. Hence the earth flylead on an RCBO is normally white.
'clean earths' will normally be combined functional and protective earths so would be coloured green/yellow. (even if not by design they will normally perform as a protective conductor)
I think certain equipment IT equipment may be provided with a functional earth, but don't quote me.
I'd be inclined to provide more specific information if this is an answer in an assignment. Poor wording could lead to lost marks if they think you've confused functional earthing with high integrity earthing.
ye I've had it marked and it was wrong also could you elaborate on what high integrity earthing is and the difference between the 2( I'm not familiar with functional earthing in the 1st place apart from google and reg definition)
Feedback was where in a hotel would you find functional earth and I'm still trying to think tbh - at the moment I'm thinking the cables used for tv boxes as i know the hotel rooms will have TVs in them - like a skybox or freeview for example. Would I be right in thinking this.
TBH, if it was an old paper written a few years ago , i would have gone for the telephone system main control unit. Hotels will have multiple exchange lines and these typically would use earth calling, however nowadays phone lines are VOIP, fed over optical fibre so no earth required there, lol
Second i would have gone for RCD/RCBO which has the cream wire which provides a reference earth just in case the neutral is out , it enables the RCD to operate,
However, quite frankly, its a bit misleading as you could easily find nowadays no functional earth at all in a Hotel.
Thats really a nasty question, better example question would be.
"How would you recognise a functional earth and give an example of where it would be used"
Reply to What is an example of functional earth? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Disclaimer: I'm not going to attempt this job myself, I want a professional to do this job properly since I consider it non-trivial and need it...
Hi, Currently working my way through my NVQ portfolio (Nearing Completion) but getting stuck on how to complete the following criteria due to...
A friend's partner has an interesting fault, if it is a fault. She sets the shut down timer on the cooker and when the timer goes off (which in...
Hi, sorry if this is the wrong place to ask, I am wondering about becoming an electrician of some form or another and thought to come to an...
Electrical Courses
