Discuss What Mistakes Have You Done? in the UK Electrical Forum area at ElectriciansForums.net
Doing an annual EM test in a restaurant when a plumber asks me to disconnect a food drainage unit that he needs to unblock. I disconnected it so he could pull it away from the wall and this thing stank like hell! Full of 2 day old food, it separates hard food and liquid then pulps it into mush.
A bit later on and the plumber asks me to wire it back up so I did. Whilst I'm crouching down next to the start button I turned it on, big mistake! All the waste food in the hopper from the past two days shot up into the air, hit the ceiling and walls then gravity took over and it ended up all over me. I just stood there infront of the chef, plumber and a kitchen porter with bits of spaghetti, chicken, veg, fish bones covering every inch of me from head to toe. I even had a piece squid dangling from my glasses! I looked a right state and it stank. After all the kitchen staff, waiters and management came to have a look at what all the noise was for, I had the restaurant in stitches. They was very nice and let me use the staff room to clean up and gave me a company tee shirt. I powered up the EM lights, got into the van and went home for the hottest shower I've ever had, phoned the boss to tell him that I'll go back tomorrow to finish off the test. Every time I look at that tee shirt I swear I can smell that god awful pukey food, I'll never forget that smell.
Worst mistakes I have made:
Picked up a soldering iron with my hand, on the element, while...still....hot ¬_¬
Found a strange chip, looked at it, held it, found out it was static sensitive......poof!....gone :'(
7805 voltage regulator, output voltage was not correct, maybe turning up the input voltage will help! Hang on, heat? oh, connected wrong way round, the 7805 never worked again.
Memory chip in old commodore 64, took em out and replaced with a single 64KB memory chip, turns out it was a PLA problem, memory was fine >:|
Carried out a IR test on a circuit that had work colleague attached to other end of it....!
Worked for Mr Electric... (biggest mistake)
replaced a blown fuse wire with a snip of 1.5 .. (temp perm fix)
bought a rover 420di
become a sparky and not a train driver..
Oh the good old days! remember when half the plugs you opened on jobs had foil from a smoke packet round the fuse?
The first time l ever installed smoke alarms, l omitted the earth, (thinking that well they made of plastic so l didnt need it) until l realised once that everything was in and fully plastered that l couldnt perform a Zs reading for the certs... Duh!!!!
Got my stihl saw out to trim some stone for me mums Dunsley boiler stove base,forgetting my mate had borrowed it previously.Checked the fuel and pull cord,never checked diamond disc was tight.Got warmed up and up to warp speed (5000 rpm) as i started the cut she jumped and set off like Usain Bolt,over junction of cul-de-sac,up kerb,over pavement main road,another kerb,off tree root along pavement past old folks home to end up rattling on deck as in cartoons.Total trip of 80 metres plus 4 PM on a weekday afternoon! Carried it back to the origin of its escape hugging it like a naughty child...
Went to see a mate on a job he was doing in an accomadation block, Needing a 'Number 2' asked him where the toiliets were and off I went. Sat down nicely minding my own bussiness and hear 2 girls come in chatting away in the cubicles next to me. I was in the females loo!! I couldn't leave until they finished and left 20 mins later incase we walked out at the same time and I looked a perve!!
Reply to What Mistakes Have You Done? in the UK Electrical Forum area at ElectriciansForums.net
Currently I’m using freeagents platform for invoicing and it’s decent and gets the job done but it’s lacking a few features. Firstly I want to be...
Bit of a rant first to explain the situation:- Effing builders again, I knew there was a reason we hardly ever work for them. We've done a few...
I have a home that is part 1940 and part 2005. The new portion is all new (well 2005 new) romex with grounds. The old is some rewired romex with...
