Discuss what ratchet crimpers to get? in the Electrical Tools and Products area at ElectriciansForums.net
N
NadHuh
I need some new pair of crimpers the 0.5mm-6mm ones. I had some cheap ones before but didn't last that long, any one got any suggestion on some good makes I don't mind paying extra as long as they last me.
You really need more than just one ratchet crimper unless you buy one with interchangable heads for insulated crimps, uninsulated crimps and bootlace ferrules etc.
Ive got some nice facom ones that hold the crimp in the die real handy! Also habe facom bootlace crimpers good quality!
How much were the facom bootlace crimpers...fancy a set as have some other facom tools...class kit...
my insulated crimpers are some HD Forge Steel ones from screwfix, a bit heavy and bulky but they do the job, tried pulling the crimp apart and failed...
Are these the ones your talking about http://hardware.lpwright.co.uk/Page_i328896
how big are they compared to the regular screwfix ones or the ck ones?
The Phoenix ones are expensive but have the interchangeable dies. Great for me as I use them for sat cable crimps as well as shoelace and lugs. The company tend to be at the trade shows where I got a better price.
I just need the ones that do the red, blue, and yellow insulated crimps.
Those PVC covered coloured crimps are just about the worst butt crimps on the market today, never use them and have never trusted them. Far better are the heatshrink covered coloured butt crimps, that you can then shrink the XLPE insulation onto the conductors. Even better, bare butt crimps that you over cover with one or two layers heat shrink tubing!!
Reply to what ratchet crimpers to get? in the Electrical Tools and Products area at ElectriciansForums.net
I’ve got some lug crimping tool called iwiss off Amazon and when crimping a 10mm cable into a lug I had to use 10mm on one side and 6mm on the...
hello , Just a note to see if anyone been in the same sort of journey as me? I wanted to retrain as an electrician at 40 and on bad advice did a...
NICEIC Certification Scheme Getting accredited to
Looking for some advice regarding joining a CPS. I've been in the electrical industry in various roles for nearly 10 years. I started my...
Hi Guys After bit of advice please as we don't do much data normally, tend to sub it out. Had garden building this week which we'd run in SWA...
