mikeup
- Reaction score
- 1
Old house / wiring / fusebox plus single circuit breaker.
So I decide to change dead double socket in kitchen ( one socket failed followed by its twin months later= no power ( yesterday ) ) NB. once it stopped working the switches on the socket were found to be stuck ( in the "on" position)
So despite being bitten by this fuse box last year ( same thing - I removed fuse which indicated it covered sockets in kitchen - but I discovered it was still live - and leaving myself a note inside to tell me ) I remove "kitchen socket" fuse and proceed as follows.
1/ test whan I assume is inline socket in kitchen and no power. Can't "test " actual socket as.... see above.
2/remove socket to find;- a/ two red wires aimed at but not in or touching live ( rh as seen from viewer ) terminal. I have no explanation as to how two very stiff wires came out of their terminal - the screw in the terminal was in the unscrewed position!!
b/. two black wires firmly in neutral ( ?) lh terminal
c. earth in far lh terminal.
I remove wires and proceed to rewire as original - earth, then black ( N) , then red (L!?)
well..to my surprise as I accidently touch red wires and earth!!!!! BANG - melted wires, melted screwdriver and blackened plastic and trip fuse trips.
whew - no harm done...
So my question is.
Will/should removing a fuse ever protect you from electrical shock?
Does the "live" always remain live ( as this did ) even if fuse removed?
FYI - I will NEVER work on any exposed wires again unless power is off!
Socket now working - rewired as old one " should" have been.
So my question is.
