Discuss Where do I put the dimmer switch? in the DIY Electrical Advice area at ElectriciansForums.net
elizabeth
I have 2 (one gang) on/off light switches in my lounge (one at each end of the lounge). I'd like to change one of them over to a (one gang, two way) dimmer switch. One back box has lots of wires - I think the wires are going in and out of there. The other back box has fewer - I think this is perhaps where the circuit ends. Which switch should I replace with the dimmer switch please or does it not matter? Thank you.
It doesn't matter you can put on whichever suits the best.
Reply to Where do I put the dimmer switch? in the DIY Electrical Advice area at ElectriciansForums.net
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
Hi all I've been changing the halogen downlighters in my house to LED's. I have three rooms that use dimmers, two of them have two switches each...
Does anyone have any experience of installing Enkin PDM250 Multi-way dimmer modules? We have 4 dimmers at different ends of the kitchen / dining...
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
