Discuss Which consumer units are best in the UK Electrical Forum area at ElectriciansForums.net
then what you are refering to is a mainboard or switchgear [emoji12]
Nope, switchgear has it's own definition and would normally encompass DBs, switch fuses, fused switches, busbar chambers etc etc.
Mainboard is not a defined term as far as I know, and not one that I think I have ever heard of before.
here you go, acti9 wall mounted switchgear
(biggest board ive worked on is Schneider powerpact4)
Cough! Getting back the original thread; Wylex, Crabtree (same group), Schneider, Hager & MK Electric are all offering their new 'Amendment 3' domestic consumer units. I'm not sure I would include any others IMHO. My local wholesalers usually stock from all these manufactories, but only have Wylex currently available off the shelf, and only in a couple of sizes/flavours.
Seems that metal 'Amendment 3' boards are rarer than rocking horse pooh at the moment, so OP, you should speak to your electrician to see what he can obtain or wait a while till the shelves get stocked up and the guys here, can give their views, once they fitted a few. IMO the Hager one seems to of had some thought put into the design, the rest seem to have put the contents of their plastic CU's into a metal box.
So the Electrician as been and straight away he mentioned that he uses the new AM3 boxes, he uses a brand called M2 which I had not heard of but a quick search revealed this consumer unit M2 Concept Automation
twin screws on tails and a pretty smart looking unit actually, I'm not sure how there fuses stack up though, anyone used them before ?
im surprised no one has brought one out with a layer of fire mastic covering the inside XD that would contain the fire.
if there is a fire it will expand and cover the lot
what good is a cable grip for the tails if the problem is a loose or bad termination
There'll be some on here that will like the dual screw terminations. I thought they looked quite a lot taller than the other makes, but their dual rcd units are 256mm high, compared to similar Wylex unit of 261mm. Doesn't appear to be any prices, are they part of Proteus, distributed by CEF?
Not sure about being part of proteus, they could be as the enclosure looks the same. I know CEF stock them as seen M2 metal boards in my local CEF. I like the twin screw terminal for the main switch, Although personally I wouldn't install one in my house as I would prefer to go for a more established make like hager. Over the years we've all seen different makes spring up and disappear leaving you in the Shyt if an RCD or mcb needs replacing or even adding a new circuit on a spare way and can't get hold of an mcb as the manufacturer isn't in business anymore. For a few extra £ hager is the best bet IMO as they actually look like they have put some thought into it with the cable entry points and cable clamp for the tails etc.
M2 is a CEF off shoot.
I personally prefer Hager.
I was in a house last week with a older Hager unit installed. I was able to easily fit the new Hager MCB's I have in the van to the 20 year old consumer unit
This is why I prefer Hager, they tend to make their gear backwards compatible, it is also a decent quality.
that is the biggest problem with Schneider gear.
ok i have a schneider board. i need a b6 mcb which one do i choose.
it could be sqaure d,merlin or a new Schneider breaker etc.
good to know about hager, thanks for that
I remember when 17th edition boards first came out and the only 17th ed boards my local Cef stocked were m2. I fitted one at my parents and when I powered up it was showing reverse polarity. Ends up the internal links were wrong thus putting out reverse polarity. Also the mcb's were crap and the plastic cracked when tightened! Never again!!
I'm going to order the Hager unit myself for the electrician since it seems he's getting ripped off or he is charging more for this M2. just to confirm that these rcbo's are the right ones for domestic. These will be replacing two light circuits fuses, 6A B, two finals 32 B and cooker on 32A B
Unit is Hag114 VML114
Rcbo's Hag ADN106, ADN132
Gil-lec is best for prices on all these
there are more than one type of isobar just to add to the confusion and the breakers look different (they still fit)
then there is easy9 and another series as well but i cant remember the name
They are on isobar4 now but they are all backwards compatible as far as I know, which is also the same as the previous (v good) MK sentry range as they were rebadged MG breakers.
Not sure... I recently had dealings with a new Acti9 DB. The Acti9 branded MCBs fitted fine but Schneider branded C60 MCBs didn't seem to want to. I didn't confirm it with Schneider however.
The easy 9 boards look quite nice once fitted. However, there isn't much room inside them for dressing cables and the internal design might as well have been designed by a small child. Why would you have a main switch on the right hand side of the board with the left terminal for the neutral and the right terminal for the live is beyond me. I wonder if their amendment 3 will be any better.
Remember the board will only have a main switch in it no circuit breakers so there will be a lot of blanks to cover up..
The RCBO's are OK for domestic use.
You would need to check that your electrician is happy with this choice, they are the one that has to fit the board.
The lack of knockouts might be inconvenient but for only five circuits not too bad.
I may have been mistaken then, but I'm sure they are backwards compatible.
They are also still making the c60 and c120 MCBs
It could just have been me not jiggling it right. That's been the case in quite a few situations before.
nope there are different schneider breakers and there not all compatable with each other
schneider-electric-ic60h-c20a-20-amp-type-c-single-pole-mcb-circuit-breaker.-890-p.jpg
the ic ones are acti9 i belive the other is the easy range but im not sure (we use ic range all the time)
Hager do one called Design 30
Hager Design 30 is a great looking board, but probably somewhat over-engineered for most applications, have you taken a look at their far more popular Design 10 range?
Even though the board cost will probably be the smaller part of the bill compared to the labour involved changing/testing from your old one, its worth considering.
Reply to Which consumer units are best in the UK Electrical Forum area at ElectriciansForums.net
Good morning guys Was looking for advice with regards to installing an outdoor consumer unit. Customer is looking for power to be installed from...
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
5K
I try to keep out of Domestic work but I have a problem at home. Currently I have a wylex fuse board with re-wire fuses. they are great because...
4K
I live in a flat in Scotland supplied with an old 2 meter system called THTC where one meter using a time signal supplied heating and hot water...
