Looks like Facom aren't any dearer than the Irazola.... I'm sure Irazola were far better before being taken over by Bahco. Thanks for the advice, I will try a set of Facom unless someone comes on here telling me how ---- they are!![]()
Facom are ----![]()
Only joking, not used them but they have a good rep
I use Wiha. I don't use a 4mm but a 4.5mm for socket terminals, and a 3.5mm for switch terminals and the like.
Their blades are 1.0mm thick in 4.0mm to 5.5mm which means a snug fit in socket terminals and 3.5mm screws, but a bigger beefier driver can be used.
I have a set of Wiha which I bought just to rob the smaller blades from. There was no 4mm in the set though. Problem is I have loads of new big screwdrivers and always needing the smaller blades, shame no one sells a set of small blades. I tend to use the 4mm for sockets and switches, but maybe I should do as you do and use a 4.5 for sockets, particularly the MK sockets which seem to have larger slots to their terminal screws.
Hi Happyhippydad... a good poll, have you done one on cutters too? I've yet to find a decent general purpose cutter...
