I have 2 smoke alarms in my house that are attached to mains electricity and have battery back.
However I assume one has become faulty because, they both started giving warning beeps the other day and the problem has continued even after replacing both back up batteries.
I assume the wired connection means that the fault on one is alrmed on both detectors.
At the moment the only way to stop the beeping is to leave both smoke alarms open with no batteries.
Which makes me think that one of the detectors is not registering the back up battery correctly
Both smoke alarms are only a couple of years old.
Is there any simple way of determining which of the smoke alarms is faulty?
Thanks in advance
Thanks in advance
Hi Probably the easiest way is to disconnect the link cable between the detectors and see which one is still giving the low battery chirp..
Depending on regulations in in your locality, mains electricity powered smoke alarms with battery backup might be illegal for unqualified (DIY) installation and maintenance, as they are a ”Life Safety System”.
Without knowledge of these systems, which can be wired differently depending on manufacturer, it is not possible, or legal to give suggestions to rectify problems. Once any work is done, the system needs to be comprehensible tested, and certified.
The only advice I can give is. Check that the breaker for the smoke alarms, (they should be on a separate circuit) is switched on and, check and replace the batteries. If this has does not cure the problem, then professional help will be needed.
Hi Dangerous, owner. occupied domestic smoke detectors can be wired of off the lighting circuit and does not require a seperate certification .
poster's profile shows he is from Melbourne Australia. They have much stricter regulations than uk. The uk regs require a single indepedant circuit for wired in smoke alarms with no other electrical equipement connected, exept grade "D" systems which can be connected to a regularly used local lighting circuit.
here is an extract of Australian requirements.
"Smoke alarms are considered life safety systems in Melbourne, Australia, as they are legally required in all homes to provide early warning of a fire, as mandated by the Victorian government and the Australian Building Code. These systems are essential for protecting occupants, and their installation and maintenance are governed by strict regulations to ensure they are in working order. "
UK info from IEE electricians guide to fire detection and alarm systems.
AU inf from internet search.
regards Brian
regards Brian
Hi Brian, I'm sorry fella I missed that, I must remember to check that before replying, thank you for you response Regards Ed
