Discuss Whirpool bath prob !!!! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Y
YTSOxford
hi all, just need 2 pick some brains over earthing. Have come to a secxond fix this week, and have to hook up this fancy whirlpool tub. The whole job is nearly complete, builders are just finishing and making good, when i realise the tub has a fly green and yellow on one of the motors. Obviously this must be to bond the jet outlets etc, but where would be the best place to bond???
Main water & gas bonding in place and all circuits on 17th ed board, so no green and yellow was run into the bathroom. Should bond to the taps, although this is that crap flexible hosing stuff, or should i just connect it to the baths junction box/ circuit box; but why hasn't this been done already???
As i sed, they have made good, so can't go drilling and knocking. Appreciate all comments, event those sacastic ones. Many thanks......
Find the most accesible circuit in the bathroom
Please ignore the preceeding reply. if all water supply rads and taps is in plastic then there is no req for supp bonding as the conduction is bconsidered to be by the Cu not the H2O
If the water is supplied by plastic pipe there is no need to supp bond because any metal pipe work showing above the floor becomes plastic below the floor and is deemed to be isolated from extaeneous conductive parts of the building. EG the towel rail might be nice shiny chrome but if everything below the floor is plastic ther is deemed no chance of a potential diff between a tap and a towel rail therfore no need for supp bond req
Reply to Whirpool bath prob !!!! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Good Afternoon All, So I have a new situation to me that I cannot seem to get a definitive answer for. I trained as an electrician and did...
I’ve just done an EICR on an old 2 bed flat that is wired in all metal conduit wired in singles however there are no CPC’s. The conduits are all...
So a quick catch up so you can get an idea… I was asked to do a job for another electrician, as he is too busy. I’m busy myself but said I’d...
A few weeks ago I posted this in another thread...: The tripping kept occurring, so I went back and moved a likely candidate circuit to the...
Need some help please. Got a brain teaser for my first post. My pool pump motor cratered over 4th of July. It was working fine and started to...
