I have only once put in electric underfloor heating and the builder basically did all the ground work.
I'm just wondering what sort of balance you guys split with the builder when you are installing it? Do you lay all the thermal boards? If needed, do you do the self levelling compound? Do you lay any boards required over the top of it? Or, does the builder do most (all) of that and you just lay the cable or foil system etc, literally just the electrical part? I kind of want to just stick to what I know.
I definitely wont be screeding/self levelling compound etc. Builder chap would do that. I would just make a mess.
