Discuss Why would a DNO do this? in the UK Electrical Forum area at ElectriciansForums.net
Hello, first non-intro post.
I'm in fixing a re-wire by a handy man and seen that the DNO has fitted a service connector block on the live tail. Sealed and stamped by the DNO?
Why would they do that?
Cheers
On further inspection I don’t think DNO fitted that isolator either.
They are much better than that. Sleaving is not fully enclosed on a couple of the tails on either side from what I can see.
As for the seals anyone can buy them.
sleeving. from the spell check gestapo.
I'm going to remove it, don't even need to break the seals as it's on the consumer side of the isolator, just thought I'd get some others thoughts on it.
I'll speak to the developer, got a potential job of 6 flats to get rewired and I want to make sure he's not cutting corners before I get too involved with them.
Reply to Why would a DNO do this? in the UK Electrical Forum area at ElectriciansForums.net
Hi all -- full disclosure I am a 'DIY-er' but wanted to post here for greater visibility seeing as I certainly won't be doing this work myself...
4K
I didn't get a picture so will have to wait until I go back again but I've done a crude drawing of what was there. Its in a commercial set up...
I'm not sure what's going on with my kitchen light. I've replaced an old 28W CFL fitting with a new 4 x LED GU10 fitting (a cheap one from...
Hello. Just a lowly homeowner here who is beginning to panic after a major house renovation regarding relocation of the main supply cable to the...
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
