there is an attachment on the market which is designed to keep the place clean, it has a bowl over it which pushes on the ceiling, should be good enough
Starret holesaw held at an angle so half of the saw is in the hole, 2 steady hands and slow speed on the drill. Cut all holes at same angle and in same direction. Try pulling the saw back against the existing cut out to keep it steady. Best of luck!!
Thanks guys some excellent advice there, wish i knew those tricks before i did the job. Oh well im sure there will be another job in the future where i need to do the same.
You could do what my son did ( he's not a sparky) he recently moved into a new house which had badly fitted downlights in his main bedroom. He decided he wanted to remove them and just have a centre light, went in the attic to move the cable and fell through. He's got a lovely new ceiling now ,so if he wanted downlights back he can start anew..
It's making them smaller that's the issue, other than re boarding or moving the lights, there ain't much else you can do.
He could fit a downlight hole converter plate
I widened around 20 holes for downlights last night. They were in suspended ceiling tiles not plaster board but the theory is the same. I put the correct size holecutter against the ceiling, gave it a little push to mark the ceiling, then cut out with knife. Easy and fast,and they all fit perfectly.
get a geordie to open his gob. then you have a perfect template. :mickey:
Dazza1976,
Geordie Spark,
