Discuss Will this degrade a GFCI outlet? in the UK Electrical Forum area at ElectriciansForums.net
BruceG
I have a wall switch controlling regular outlet.
If I replace the regular outlet with a GFCI outlet, will turning Off-and-On (power to the GFCI outlet via the wall switch) degrade the GFCI outlet over time?
Reply to Will this degrade a GFCI outlet? in the UK Electrical Forum area at ElectriciansForums.net
My daughter asked me to replace a standard outlet on her porch with a GFCI outlet. We installed it correctly but were not able to get it to work...
Hello. I am new to wiring and could use some help getting this circuit wired in the kitchen . I am trying to get the source power to the GFCI and...
Hello all! Newer house, original owner(Florida). no change to electrical system. Just found there was an outlet (GFCI) in the closet so I wanted...
I have a small power washer with a two-wire cord and GFCI plug. My outdoor and garage receptacles are on a "house GFCI" circuit, wired in series...
I plugged a drill press directly into a GFCI outlet in the garage. Something blew up by the drill press switch. Since then the GFCI outlet LED...
