Discuss wire in walls in the Canada area at ElectriciansForums.net
Rum old fella, we live in a highly compeitive working world where time IS money regardless of whether we like it or not. We cannot simply go pulling new circuits in just to avoid crimping and plastering over. I have to do it regularly and although I think it is sometimes not ideal - it is the only option. Sparks HAVE to be quick (and safe) in todays working environment so I suggest you embrace the change my friend cos times are changing.
Total rubbish ,your brainwashed,take your time ,do the job to your Best abillity and set your standards high,that way you will earn yourself a good reputation in the trade,there are plenty of employers out there who dont care how long a job takes ,as long as its right,and there are plenty of electricians all wanting to be the quickest,it always makes me laugh when i see them ,rushing about ,no t break,thinking theve got a good job.
chill out a bit ,relax into your work ,perfect it ,then think about going about earning the real money;)
If I chilled, took my time and had tea / lunch breaks then I would not get my work done. I would also only earn £11.79 an hour whereas if I rush and work quickly (but accurately) I earn double that. Bit of a no brainer really is it.:rolleyes:
Bit of a hare and tortoise situation :)
Yup, but sadly, being a tortoise doesn't pay the extortionate mortgage I have and the nice cars and the holidays etc etc etc. Modern day living I'm afraid.
Your strategy seems to be working for you ,mine works for me;) have fun and for ****s sake chill out .you will end up with a heart attack,ive had one so im ok now:)
cant recall anyone giving the correct reg number to this question;
try526.1 to 526.5 17th edition
rum ,may we have another atvbitwww:D
hi wayne ,you could always post it up ,for those who havent got the book ,i dont need to know it personly ,i would never do it under any circumstances ,and i would ask anyone who did to change it ,so it dont matter whatever it says in the book really.
atvbitwww
Rum, you aboslutely shock me
you come on here pontificating about about how wonderful your standards are, criticize my teaching and ethics, simply becuase you appear to have difficulty in interpretating plain english, when all the time you are working as a sparks when you are not even qualified to the 16th edition, never mind the 17th edition
And heres the news flash - you DO need to know it. If you dont know the current rules then ergo you cant know:
A. When you are complying with them
B. When you are contravening them
Now i could go into a long tirade about the difference between acceptable practice and best practice, but quite frankly Rum, i dont think you would listen
Additionally, try reading my posts - when i did i ever mention plastering over crimped connections?
Yes, i discussed crimped connections buried in walls, but theres more than way to skin a cat
plastering over them after sealing them would be a solution.
Crimping them inside a sunken architrave box, then putting a blanking plate over that would be a better solution
crimping them and then sliding some oval conduit over the joint, and sealing it before plastering would also be better than just plastering over
and relacing the entire cable would be an even better solution.
However, Rum, theres the ideal world, where we use the best solution, and the real world that people like me and Ciruus inhabit, where sometimes we have to adapt a solution to the environment
Now if i told my students 'the only way is to replace the entire cable' that would be a lie
whereas if i said 'the BEST way is to replace the entire cable, however these are other soltions that are available to you' then that would be a true statement
And I reiterate my point Rum, if you do periodics, and pick something up you have to number it between 1 and 4 and back it up with a regs number that has been contravened
and in this case, YOU would not be able to
and finally Rum
Reply to wire in walls in the Canada area at ElectriciansForums.net
Hi All, As a householder I'm keen to add a double socket further along a wall to extend access in a different corner of the room. I'm connecting...
Hi all, I am planning to install wall lights such as these ones (LAP Bronx Outdoor Up & Down Wall Light Black - Screwfix -...
I have Liebherr fridge freezer and need to extend the cable from the appliance to the wall plug. The directions do not allow an extension lead to...
Hi, I have a coaxial wall plate that is hanging off the wall and needs replacing. How do I wire the old plate which has an IN and OUT for the...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
