G
gr0mit
Hi all Newby here in dire need of advice
I have managed to lose the wiring order on my fiat fiorino van starter motor
I have 3 wires
1 Goes to alternator
1 goes to battery
and 1 goes to either ECU or ignition
Battery has 12.97 volts (its Fine)
The battery definitely connects to the empty terminal
My new starter motor only has 2 teminals on it same as old one
The wire that i suspect goes to ECU or ignition has a large ring terminal on it
The Alternater wire is normal size ring terminal.
The battery wire has i plastic housing to protect its connection to the Motor
I have checked battery and tried with just battery and alternator on the only unoccupied terminal
i attatch pictures of starter motor solenoid connections pls help many thanks
sure a fiat dealer could advise.
