Discuss Wiring a fiat starter motor in the Auto Electrician Forum area at ElectriciansForums.net
gr0mit
Hi all Newby here in dire need of advice
I have managed to lose the wiring order on my fiat fiorino van starter motor
I have 3 wires
1 Goes to alternator
1 goes to battery
and 1 goes to either ECU or ignition
Battery has 12.97 volts (its Fine)
The battery definitely connects to the empty terminal
My new starter motor only has 2 teminals on it same as old one
The wire that i suspect goes to ECU or ignition has a large ring terminal on it
The Alternater wire is normal size ring terminal.
The battery wire has i plastic housing to protect its connection to the Motor
I have checked battery and tried with just battery and alternator on the only unoccupied terminal
i attatch pictures of starter motor solenoid connections pls help many thanks
Reply to Wiring a fiat starter motor in the Auto Electrician Forum area at ElectriciansForums.net
Good evening all Ive got an old truck 1990 that has always had intermittent starting issues whilst ive owned it.. As far as i am aware the...
I have an interesting starter circuit issue on a 2001 Toyota Celica (that won't start). If I have the starter out and have the main positive...
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Hello everybody from Germany! I'm feeling sick with this car, it won't start, just very rarely...please help me out. Car: Opel Corsa C 1.2 2003...
Hello and Happy New Year. It's not starting too well for me, excuse pun. Since Friday December 16th, The 2.4l Duratorq diesel won't start...
