Discuss Wiring assembly on chandelier in the DIY Electrical Advice area at ElectriciansForums.net
Hi all. Hoping to get some advice.
I have received a chandelier consisting of five lights. I have to assemble the fitting however there are five exposed pairs of live and neutral wires that are to be connected to individual live and neutral wires that will ultimately connect to the house.
How should I connect the five live and neutral wires? Do all five lives connect to the solo live and likewise for the neutral? Or do I daisy chain the five together, connecting live to neutral for each light?
Thanks in advance!
Can you show a pic.
At a guess they should have been connected by the manufacturer.
Ideally you need 6 way lever Wagos to connect them together but IIRC the largest they do is 5 way???
6-Way Push-Wire Connector 773 Series Pack of 50 | Cable Connectors | NoLinkingToThis - https://www.NoLinkingToThis/p/6-way-push-wire-connector-773-series-pack-of-50/22261
That's appalling that they sell a product like that .............
Zero thought gone into that. Is it brand new?
THEY WON'T DO FOR FLEX.you could use a 5 port and a 2 port lever type for each.or the dreaded choc block. it's accessible by dropping the fitting and it's what the manufacturer would use if they hadn't any fire nuts handy.
an alternative would be to twist and solder, then put in choc block. all the browns in one, blues in another, E's in 3rd. then the fixed wiring in the other side.
You’d think that they’d provide ferruled ends - you’d be able to use a push fit 6 way then.
It certainly doesn’t help the ‘end user’ usually being us the electricians who have the tools to adapt and engineer stuff to make it work - what chance do the ‘little people’ have.
Choc block it is then - ‘head held on shame’ cough cough! (I’ve got a cold!)
Second hand fitting.
I like this idea best.
Fine stranded conductors are difficult to get into them without some of the strands poking out unless you use ferrules.
even using ferrules, it's almost impossible to get fine strand flex into push-fit wagos. the flex just buckles up. DO IT ONCE DO IT RIGHT.
Reply to Wiring assembly on chandelier in the DIY Electrical Advice area at ElectriciansForums.net
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hi, I need some advice on the wiring for a new ceiling light. I have taken down the original light, and I'm left with the wiring in the image...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
