Discuss Wiring diagram?? in the Lighting Forum area at ElectriciansForums.net
It is just two way switching with two intermediate switches so the light can be controlled from four different positions. Not sure why the two two-way switches say use as one-way.
I not sure how to put some cable correct, But I not have wiring diagram?
Middle switch is intermediate, but still confused ?
Show us your attempt first, you should know by now we don't give out answers with out some sort of answer by the OP.
Because they've got the question wrong again. This seems to be a recurring theme; perhaps it's deliberate.
OP: ignore the comment about 1-way, any circuit controlled at two or more positions needs two 2-ways and the rest intermediates. Use the two 2-way switches as 2-way, add in the intermediates and wire the fluorescent fitting as shown.
Reply to Wiring diagram?? in the Lighting Forum area at ElectriciansForums.net
I have a led panel that i want to dim. It is dimmable but without a dimmable driver. I have a dimmer module and a dimmer switch as shown in the...
Hi Total novi e but have wired multiple light switches previously and survived :) I've bought a nice WiFi enabled dinner switch for a new LED...
Greetings. I am new to this forum and I have a question regarding a relay that I am installing on a motorcycle wiring harness. What I'm trying to...
Good evening Sparks and Sparkles, Has anyone got a wiring diagram for a storage combi boiler using a Hive (plumber says 1 channel...)... The...
Hi everyone, please advice and comment on the attached wiring diagram for a kitchen. There are mixed opinions on the need for FSU-s and number of...
4K
