Y
yellowbruce
Hi All,
Does it matter what side of the MCB you wire to for correct operation, when they are not mounted in a DB.
Regards
Most mcb's have no preferance to direction of current flow,so yes they will sense overcurrent either way. In fact single phase consumer units can differ from its 3 phase counterpart in relation to busbar mounts. ie top of the breaker in one board is the bottom of the breaker in another.
99% of modern mcbs work either way. Only RCD 's i have come across don not like incorrect 'in & out'
SLOCM There are many reasons where mounting a mcb not in a DB occurr
