Discuss Wiring outlets in attached garage in the DIY Electrical Advice area at ElectriciansForums.net
decova
My house is a small 3 / 2 with an attached garage. Recently a new circuit was added to install 2 new ceiling fans in the patio. Can I use the same circuit to add an outlet in the attached garage? Or, does a garage require its own circuit. My garage is not a shop so no plans to run power tools from the new garage outlet. My garage is void of any outlets. What is the code for wiring an attached garage? Thanks
I really don’t see a reason that you can’t add a receptacle since only 2 fans are on that circuit. Good luck
Thanks for your reply. But, does the NEC allow me to comingle outlets in an attached garage with devices in the house, such as a ceiling fan, on the same circuit? Thanks again.
Reply to Wiring outlets in attached garage in the DIY Electrical Advice area at ElectriciansForums.net
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
Recently moved into a house from the 70s. There's no ceiling light in the living room. Assuming the switch for the room was to one of the outlets...
I’m planning to run an electrical sub-panel to my detached garage (about 150’ away) and run it off my 200 amp home panel. I live out in the...
Hi there. I am a DIYer and am located in Ontario, Canada. I would like to put in a dedicated 20 amp circuit into my attached garage for my 15 amp...
