L
lofty84
Hi guys if anyone could help me out here I would really appreciate it. I've got to wired up a immersion heater. There is a switched fused spur mounted on the outside of the cupboard housing said immersion heater from this is a piece of flexed which need to be wired in. On top of the immersion heater is somewhere for the cables to go on the left is a heatrae terminal with a minus sin above it and on the right is a rdg terminal with a plus sign above it i take it live goes to the right and neutral to the left and the earth to the bi screw which says warning this alliance must be earthed. If so I will need some sort of earth crip and then a nut to tighten it down and make sites there a good solid connection. Any help greatly appreciated as there waiting on me to do It
Hmmmmm
lofty, i cant believe so many people are taken in by your threads, your keyboard must be soaking wet with tears of laughter dropping from your eyes while you are typing!
Carry on bonny lad ....... if, when ye switch it on the wattor gans hot, ye've gorrit reet.
If it gans BANG, then ye've gorrit rang !!
Simples !!!
I'd sooner it didn't go bang can someone please be nice and advise me
Pretty please with a cherry on top
think it's time for some serious reading. this job is just one step above wiring a plug top.
I take it you're using an AC supply, rather than DC? In which case, the + and - will be the thermostat temperature setting and nothing to do with the supply connections.
Lofty, it's just a Resistive load, it don't matter what way round yous join them wires to it.
My fingers are itching...but I promised myself that I wouldn't say things like "Are you actually an electrician, charging people for doing work you have no idea how to do?" anymore. :)
