Discuss Wiring up my shed 240v in the Commercial Electrical Advice area at ElectriciansForums.net
I am going to get an electrician to hook the wire up to my fuse box but I was wondering what cable I will need. I am planning on running the cable myself to be hooked up later I am after a cable to withstand 60 amps. What cable will I need
60a? What are you doing/growing in this shed?? Also there are many factors to take into consideration before choosing a cable size such as length, how it is wired etc
How long will it be, how is it going to be installed, what type of protection will it have, what is the earthing system, are there any extraneous conductive parts in the outbuilding, do any other de-rating factors need to be applied, what is the maximum permissable VD?
And of course, how much of the work is the electrician who is connecting it happy for you to do? Bearing in mind they will have to sign the certificate as if it is all their own work so anything you do needs to be up to their standards or better.
@2189clarky let your electrician design and specify the job. If you do the digging and backfilling, you should save a few £ He/she will need to inspect the cable throughout, so it's not as simple as giving your sparky two ends to work with.
As an aside, is your shed suitable for welding work, in terms of it's construction? I'm thinking fire risk assessment, ventilation, etc.
I would also presume you don’t have an upfront RCD, an industrial welder of that size is probably going to leak a bit of current. You’d be wanting an RCBO preferably or none at all, but if memory serves on all domestic sockets it’s required even for sockets above 32A
Reply to Wiring up my shed 240v in the Commercial Electrical Advice area at ElectriciansForums.net
I've wired some cable to a small 3x3 shed with 2 gpos, a 15a GPO, and a light. The shed is about 2m away from the house on a concrete slab. The...
Hi, I'm looking to get the lionshare of a small shed wired before a friendly electrician does the needful. I'm a confident DIYer, but I would...
Hi everyone. The title should sound crazy enough, but it's what happening in my 72-years old home we've purchased 2 years ago. I found the crazy...
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
