Wiska boxes are very good and never had a problem with one yet. If you are connecting SWA into their boxes, it makes sense to use their earth plates too.
no offence at all, I was interested to see what people thought on the brand and products really, both good and bad if any it's important sometimes to listen to what folks want or don't want?
You'll find the name comes up a lot on threads dealing with CU fitting especially concerning TT installs but some form of gland even if not Wiska makes a professional finish and maintains Ingress protection if it's needed.
Not a fan of the domed Wiska IP boxes. Had issues with a couple of them not sealing fully around the lid. And the wall was defo straight.
I use the A-boxes instead now. The 110x110mm being my favourite as it has rigid knockouts rather than the soft rubber diaphragms on the 85mm boxes.
Wiska glands I do like. A lot. Little things like the inserts they do for reduced cable diameters whilst allowing you to use the same gland size is a good idea to keep things looking nest and tidy.
