Well as far as plastic joint boxes go they are the best super strong no screws to corrode threaded gland entry and excelent IP rating.
More the point - why do you ask? On your first post? I smell a . . .
Oh. Ok - great range of products and the flyer for the wiska 3rd amendment metal stuffing gland for tails is my favourite flyer.
Wiska boxes are very good and never had a problem with one yet. If you are connecting SWA into their boxes, it makes sense to use their earth plates too.
no offence at all, I was interested to see what people thought on the brand and products really, both good and bad if any ;) it's important sometimes to listen to what folks want or don't want?
You'll find the name comes up a lot on threads dealing with CU fitting especially concerning TT installs but some form of gland even if not Wiska makes a professional finish and maintains Ingress protection if it's needed.
Used them a lot for outdoor lighting with Wago cage connectors. Usually do up the earth screw till it squeaks.I find they do a neat job.
Not a fan of the domed Wiska IP boxes. Had issues with a couple of them not sealing fully around the lid. And the wall was defo straight.
I use the A-boxes instead now. The 110x110mm being my favourite as it has rigid knockouts rather than the soft rubber diaphragms on the 85mm boxes.
Wiska glands I do like. A lot. Little things like the inserts they do for reduced cable diameters whilst allowing you to use the same gland size is a good idea to keep things looking nest and tidy.
There alright. If glanding SWA's for lighting I prefer to use galv Y boxes than wiska boxes and their earth clamps.
