Discuss worcester bosch WAVE thermostat on S-plan? is it possible? in the UK Electrical Forum area at ElectriciansForums.net
hi
Just wondering if a worcester wave thermostat will work on a modern worcester bosch system boiler with a pressurised cylinder (1 x 2 port for heating, 1 x 2port for hot water/cylinder)
I don't see how it will?,
any help, thank you
No it won't, to use the wave you will need the internal diverter valve for the boiler with the CH and DHW flow and return pipes run back to the boiler seperately.
To use Worcester intelligent controls with an S plan system you would need to use the greenstar wiring centre with the comfort range of controls.
But the greenstar wiring centre setup is a load of rubbish that has caused me to loose a few days labour due to constant callbacks and Worcester engineer visits that have resulted in Worcester issuing a hurried 'bodge' solution to the problem.
hi
any help, thank you
It won't work how it is now. It'll be a great deal of work/money to get it to work....optional extra worcester integral diverter valve and a bit of re-piping and then not entity sure how you would get round the required interlock on the unvented cylinder without looking in to it,Thermostat would connect to the ems/bus connections..........choose another thermostat lol.
edit: took me so long to type whilst cooking dinner, Davesparks beat/explained it better :)
For an unvented cylinder you wire the overheat cutout into the permanent live feed to the boiler so that the whole system shuts off on overheat.
Another classic Worcester bodge ;)
Rather than start a new thread - and having just naiively purchased a worcester wave control for my worcester 42cdi classic boiler, does this work with a standard S Plan system with a traditional vented cylinder?
Cant find any wiring information on worcesters site.
Please tell me I dont have to buy a fancy wiring centre and have to go wet side as well to fit a diverter valve as well.
The 42cdi classic is a combi from what I see. The 40cdi is either regular or system. Might be worth phoning Worcester in the morning with your gas council number of the boiler.
okay - I get the naming confusion now :)
Let forget the names!
It is a regular boiler (without internal pump/control valves) connected in an S Plan configuration with external pump and a 2 port valve for heating and a 2 port valve for hot water. All pretty standard stuff really.
I was just looking for a wiring digram to confirm how to update the wiring to suit the Wave.
I get the BB connection for the controller but clearly something else has to be amended too.
Its only compatible with a system or combi boiler.
No the wave won't work.
You're better off getting a NEST or HIVE etc to achieve the same kind of functionality.
Worcester do offer a system for an S plan conventional boiler but it is horrible
Reply to worcester bosch WAVE thermostat on S-plan? is it possible? in the UK Electrical Forum area at ElectriciansForums.net
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
Hi folks, I'd like to get my Nest thermostat up and running with the gas combi boiler (Worcester Greenstar HIghflow 440 Standalone). FYI - I...
Hi all looking for some helpful advice I'm an Aussie so go easy on me, I have a good mechanical engineering head but first time plumbing and...
Hello everyone. Budding DIY enthusiast fascinated with how things work - and, to a lesser degree, fixing things that are not working. I suppose my...
Hi everyone, my house has an air-to-heat system that generates hot water in a boiler. This boiler is then connected to the central heating...
