Discuss Would 10mm tails be acceptable? in the UK Electrical Forum area at ElectriciansForums.net
Can anyone else remember using 6mm tails looping out of a Wylex board main switch to supply a new 1 way board for a shower? [Or other additional circuit]:)
Am I right in thinking wylex boards had dual incoming terminals for exactly that purpose once upon a time?
I'm sure I've seen this on really old boards.
I've seen that Dave but rarely, more common to see the far left of the busbar [furthest away from the main switch] with terminals at the bottom the same as the outgoing 'ways' - you could loop from this and the neutral bar to an 'Extenso' unit as Freddo mentioned and this would just be an enclosure with a couple of fuse carriers isolated by the original main switch.
Reply to Would 10mm tails be acceptable? in the UK Electrical Forum area at ElectriciansForums.net
Evening all. I have a question as I can’t get my head around something with solar PV I’m going to be working on a new build in a couple of...
Hi all, My question relates to the omission of overcurrent protection (specifically overload and fault protection) at the origin of an...
Hello All, new to the forum. Would be grateful for advice on whether the following proposal is an acceptable solution or open to any suggestions...
5K
Hi guys I am taking on a job of supplying/wiring a summer house which is in the process of being built. Consumer unit has no spare ways so my...
Hello all. 17th edition sparky here, but not been on site for the last 3/4 years (had a bit of an accident). Just bought a house with a 16mm 3...
