Discuss Wylex RCBO,s in the UK Electrical Forum area at ElectriciansForums.net
5544
would a modern Wylex RCBO fit onto an old (probably the first RCD main switch wylex board) with NB30 breakers. got to fit one for a shower and do question the compatibility?
many thanks in advance.
Probably best bet is to fit a stand alone 30 ma rcd & enclosure just outside the board , fairly sure you won't find an RCBO for that board ...
Reply to Wylex RCBO,s in the UK Electrical Forum area at ElectriciansForums.net
What are people fitting in the 3 phase range just lately, I've had a scan at various makes and it seems to be a ---- up between Hager and Wylex at...
So here is the thing Rhere is an old MEMSHIELD TPN+E Board that is pretty mich obsolete. The only place that sells their breakers would be Ebay...
Surely if you fit an RCBO on each circuit, an RCD is not required? Of course, a DP Main switch would be to cut all power, but like I ask, is the...
I may well need to change all the MCB's for RCBO's in this board (see picture). Do Wylex RCBO's fit in this board? It is currently fitted with...
8K
