A
Adam W
I've never fitted a transformer fed doorbell before.
Today I had a musical doorbell which didn't work. I opened it up and there was a resistor on the circuit board with signs of burning, and it was hot to the touch, so I decided to replace it for a buzzer, which would also have made the place less tacky.
The previous unit had 4 connections in cat5; upon further investigation it seemed there was a (2 wire) feed to the unit, 2 wires to the push switch, and 2 other wires which I couldn't identify. The push switch wires were linked in the CU.
I shorted out the push, 3 plate'd it at the new buzzer as I thought it should work, and the buzzer was on permanently at low level with the push light on, then became louder when the push was pressed.
I tried various configurations then took the bulb out of the push switch and everything worked ok.
The question is: How do you get the light in the push switch to light up without the buzzer going off?
No idea without seeing it, I've done a few doorbells, the light always goes out when you press it.
It's possible (almost certain) you've got the wrong voltage being supplied there, which would also account for the toasty resistor in the previous unit.
Check which tap on the transformer it is connected to, I think from memory it should be 6/8V for them.
Simple solution
Not sure what you mean by 3 plated as the transformer, the push and the bell need to be in 1 "loop" normally, so the circuit "completes" when the push is operated.
Did you read the instructions??
thfaintly.e bulb in the push is connected across the contacts. the small current passing through the bulb is enough to sound some buzzersd
Bellwire from Tx to bell and another one from bellpush to bell and you get the same connections at the bell as you would at a light.
or buy a wireless doorbell.
Yes, that. Sadly it didn't come with any instructions, it just came in a blister pack.
I measured the voltage at the buzzer which was about 5v.
What in the name of god is this doing in the Arms? I was under the impression this section is for professional electricians.
It was put in the arms in an attempt to prevent some smart Alec from skim-reading it and assuming it's a question on how to wire a simple buzzer to make it work.
I know there are a lot of domestic electricians who come on this forum, so I would have thought at least one of them would have come across the same situation and found a workaround.
I've answered your question, now can you answer mine?
Take the lamp out of the push, see if it works then. If it does then check the rating of the lamp. I’ll lay money on this being cheap crap and not properly matched.
answer is simple. the push lamp parallels the push button. this is why it sounds faintly as you have the push button bypassed with a resistor. swap the bulb for a LED bulb with appropriate series resistor.
Adam W,
Geordie Spark,
