L
Ldm
What does your mentor say about this?
No mentor. Late in life career change after leaving the army. I get as much help from those I work with (for free mostly) but use this website occasionally.
Sorry this is CONTINUITY NOT POLARITY.
Not sure if my tester can do polarity test. It's a fluke 1651b
No diagram
To test polarity on your dead test. Do the normal test them switch off And then sees what happens when you try the test again
If your tester is capable of doing a continuity test then surely you can do a polarity test?, would you carry out a polarity test with a tester which tests continuity live fella?Im sorry? I don't follow
You mean 9 lights?Hi guys and girls. Got a problem on a lighting circuit.
The circuit has a junction box which I have just labeled up.
Theres only 5 lights
OUTSIDE LIGHT x2
SIDE LIGHTS x4
MAIN LIGHT
BEDROOM LIGHT x2
the main light and side lights work the problem is the rest on the light none of them switch.
A volt test shows 240v at the switches with them in both positions.
IR test shows >500 on my fluke
continuity shows fine
earthing is ok.
Anything you you need extra please ask. I'm stumped on this one. I know it's going to be something simple.
You mean 9 lights?
Someone will pull you up on your comment about the lights being wired in series. I assume you know why. I am not nitpicking here by the way, it could be an important point. Daz.5 lights the x2 and x4 are lights wired in series. Sorry should have been clearer. There is only 5 switch lives in the junction box.
Have you checked the lamps?
Ldm Are you saying all the lights were working b4 you began, then you’ve installed some LEDs now most of he lights don’t work ?
