Doing an insulation resistance test on a shower, can someone explain how to bypass the neon in the isolator? Do most people chock block bypassing neon or another way?
Also for a lighting circuit with flurocents?
I just remembered, in a lighting circuit with a dimmer switch you need to bypass the dimmer switch.
