• If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
  • Please come check out EFbot; Testing thread is here. Come see what it can do. . Tag it in any thread using @efbot you will need give it a few seconds and refresh a page for it to post a reply post.
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
A
Alanm1969
my eldest son has autism and learning disabilities. One of his behaviours is messing around with lights - either switching them on and off rapidly for a few seconds or going around switching on all the lights in the middle of the day.
Yes, we could go into the kitchen cupboard and use the mcb to switch off but a) they are not designed for regular switching on and off and b) it's a pain to do it as we have to lock the cupboard doors!
What we would like is something that I presume can be wired in close to the mcu that has wireless connectivity so we can switch off more conveniently. Is this possible?
If not wireless, then we need to have a switch somewhere that is more convenient to use but hidden from my son (perhaps with a closure over it?)
Many thanks,
We have two 6a circuits with all light fittings led except for a fluorescent tube in loft.
Alan..
Much cheaper and easier to fit LED bulbs in all light fittings, so if the lights are left on the useage won't be much...
Wow - immediate response - thanks guys. And all in agreement too! Can pass this on to sparky when he arrives!
Alan..
not on my watch. 2 circuits in 1 switch is bad practice, unless you meant 2 switches, 1 for each circuit.
Sorry, I missed the final paragraph of the OP which stated two circuits. I wouldn't put two circuits across a DP switch either!
There could be advantages to having two separate switches so not all of the lights have to be isolated at once. It could be done with 2 grid switches on one plate.
