• If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
Currently reading:
Electrician Jobs Switch for entire lighting circuit?
Discuss Switch for entire lighting circuit? in the Electricians Jobs area at ElectriciansForums.net
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
A
Alanm1969
my eldest son has autism and learning disabilities. One of his behaviours is messing around with lights - either switching them on and off rapidly for a few seconds or going around switching on all the lights in the middle of the day.
Yes, we could go into the kitchen cupboard and use the mcb to switch off but a) they are not designed for regular switching on and off and b) it's a pain to do it as we have to lock the cupboard doors!
What we would like is something that I presume can be wired in close to the mcu that has wireless connectivity so we can switch off more conveniently. Is this possible?
If not wireless, then we need to have a switch somewhere that is more convenient to use but hidden from my son (perhaps with a closure over it?)
Many thanks,
We have two 6a circuits with all light fittings led except for a fluorescent tube in loft.
Alan..
not on my watch. 2 circuits in 1 switch is bad practice, unless you meant 2 switches, 1 for each circuit.
Sorry, I missed the final paragraph of the OP which stated two circuits. I wouldn't put two circuits across a DP switch either!
There could be advantages to having two separate switches so not all of the lights have to be isolated at once. It could be done with 2 grid switches on one plate.
Maybe leave him with some restricted form of control of a main room light ,( where others may be invading his space ).
Hiting a button shuts main lights off instantly for 20 sec maybe , then will lock out for 30 min . As it is a form of communication with others in the room .
(A magic trick he could perform ) .. Stressful if removed !
Hi Alanm,
If you try to protect your light equipment and also electrical consume and if your electrical Panel have for security I.D. (Interrupter Differential) whom is also one for Lighting and one for Sockets then, you can use an Photo-Sensor (Crepuscular Sensor or another electronic photo-sensor) and electric Contactor connected in serial circuit of Lighting I.D. to electrical Panel. This will work Off for Lighting house in a Sun day and On for all circuits when begin the Night automatically. Also where is places in a house without windows (like a Bathroom for example) you can separate this circuits from electric Contactor to let them in old connection in electrical Panel and other's circuits what you don't need use in Sun day make a new connection to the electric Contactor. The Sensor will be connected in serial connection with Coil of the electric Contactor for command this Off and On. Also, you can call an Electrician with Autorization if you can't do this work alone.
(Message form my wife who cares for autistic children and adults)...
What a brilliant idea static zap. I'll be getting Aldo (MrLights) to wire up something like that for one of my clients :)
Hi Alanm,
Whilst the words appear to all be English, they make no sense at all.
Try writing in coherent English, there's no time limit on how long you take to write a post so take it slowly and proof read it so that your posts actually make some sense to those who read them.
How about an overall timer for the lighting circuits so off during the day but automatically on for night (allowing local switching on and off) then an override to allow day use if needed.
Reply to Switch for entire lighting circuit? in the Electricians Jobs area at ElectriciansForums.net
