W
Weymark
He did everything, the board, the box on the outside of the wall and all fittings. I believe he also checked for voltage fluctuations. Hence he is now suggesting that he will need to life the flooring above to look into it more. How likely is it that we will find something away from the fixtures though? Lifting floors will certainly cause chaos, which I would love to try and avoid.I'd go with post #3 consumer unit tightness check. Did the electrician go into the board or just the fittings?
