Do they sustain illumination with the test facility for a period of time say 10 minutes.
I am just wondering if you are quickly flicking them on with the test facility to verify operation but when you turn off the breaker there is sufficient time getting to the fittings from the board for them to fail in other words they briefly illuminate and then fail.
The lights illuminate when the test switch is operated.
The lights do not illuminate when power to the entire installation is lost, ie. a power cut.
That is not likely to be caused by the lights being fed from a different circuit.
My guess would be that the test switch is incorrectly wired so that it is connected to the switched live terminal thus switching the light on rather than simulating a power failure.
If this is the case then it probably doesn't have an unswitched supply at all and so the battery hasn't been charged.
If they're non maintained and work on the flick test then they will work in a power cut.
You must be switching the wrong MCB off.
He has stated that they did not work in a power cut.
Don't assume that the test switch has been wired correctly,
Depending on where the board is they may illuminate for a short period then have failed by the time he gets there. He may only be flicking the test facility quickly but need more info and he seems to have gone.
It's seems unlikely if they have new batteries, but of course is not impossible.
The OP doesn't say explicitly that the charge indicator goes off when the test switch is operated, only that it did when the supply was pulled. The only consistent explanation seems to be Davesparks'...
May have replaced batteries due to previous failure when in fact that wasn't the issue, like you say maybe no permanent supply or the fiitings have duff charging parts.
