looks Single pole switched neutral to me.Delete.
DP or SPSN RCBOs are a very good idea and are very useful in many circumstances.What do you think about these kind of rcbo ? Do you use them ? Should be nice for a situation when there is no extra space in the D/B
Double pole will have overcurrent protection in both poles. Single pole switched neutral will obviously only provide overcurrent protection to the line side.From Schnap website;
Double pole, clearly takes up 2 ways;
LANX RCD/ MCB Double/ Two Pole Safety Switch 16A - http://www.schnap.com.au/circuit-protection/electronic-two-pole-rcbos/lanx-rcd-mcb-safety-switch-16a.html
Single pole as per O.P only takes 1 way, includes a warning re not reversing connections, presumably as the neutral isn't switched (second picture);
LANX Single Pole Safety Switch 16A 30ma 4.5KA RCD MCB - http://www.schnap.com.au/circuit-protection/rcbo/lanx-single-pole-safety-switch-16a-30ma-4.5ka-rcd-mcb.html
Ok these only take up 1 way but are they D.P. switched and you would have to have a consumer unit as they do in Europe I think that has these neutral bus-bars as photo to take D.P. mcb's same size as our standard s.p m.c.b.'s.
