I did like your suggestion, and purchased the link you sent. However the wife doesn't like the fact that the switch is towards the top of the plate and the light switch is in the centre of the plate. Don't ask!! So the idea was if we got a fuse switch then it isn't as bad the switch being at the top!I have already given you a link with a DP MK switch without a fuse.
Didn't you like my suggestion?
Your existing switch doesn't have a fuse, why do you think you now need one?
Use a fused DP FCU if you like.
You can change the fuse in there for whatever value is appropriate, but it's not necessary for a fan on a lighting circuit.
