Thanks for wago suggestion - I can see your point totally but it feels a bit cowboy ish.
Funnily enough, that was going through my mind as I was writing the suggestion. I was actually wrinkling my nose at the time, shaking my head a little.
I would use gregs and re locate the rose to the side of the light. If not you could batten it out to accommodate a wago light box. I think your being pedantic about wago's resting on top of the fitting.
led battens...?
I like the round dry line box idea but would still like a cover on like a blanking plate with a hole drilled for the flex to go through.
I thought it if I had to have a box at the side of each light the click ones that plug might look best.
I'm gonna have a play about with some of your ideas today and see which work/look best. I'll be back.
Well, lo and behold, I took the first fitting down and what do I see? A metal conduit box behind the ceiling that the wires come out of. Perfect, gives me room to terminate and with the fitting in place my IP ratings are intact. Happy days.
Thanks for all your responses.
Greg's the bakers?
As these lights are for a trial and you're set on a particular sealed unit HT I'd be inclined to fit a ceiling rose where the wiring comes through the ceiling and connect the flex there, you could reposition the new fittings slightly or use hook plates and very short lengths of jack chain to give clearance.
That'd be my solution, if the ceiling will allow.
This was my first thought, if there isn't room for a ceiling rose as suggested below.
And no, I've never come across a dry lining architrave box. It'd be handy....
