T
Toneyz
Klick ceiling rose.
Funnily enough, that was going through my mind as I was writing the suggestion. I was actually wrinkling my nose at the time, shaking my head a little.Thanks for wago suggestion - I can see your point totally but it feels a bit cowboy ish.
I would use gregs and re locate the rose to the side of the light. If not you could batten it out to accommodate a wago light box. I think your being pedantic about wago's resting on top of the fitting.
Greg's the bakers?
It's what the old boys call click roses, got think about Pete and Tel.
That'd be my solution, if the ceiling will allow.As these lights are for a trial and you're set on a particular sealed unit HT I'd be inclined to fit a ceiling rose where the wiring comes through the ceiling and connect the flex there, you could reposition the new fittings slightly or use hook plates and very short lengths of jack chain to give clearance.
This was my first thought, if there isn't room for a ceiling rose as suggested below.Is the fitting wide enough to cover a round dry line box?
Scolmore Click WA108P Circular Dry Lining Fastafix Cavity Box for Pendants, Ceiling Roses and Conduit Boxes 35mm - Wiring Accessories - Electrical - https://www.powersaver.co.uk/electrical/wiring-accessories/scolmore-click-wa108p-circular-dry-lining-fastafix-cavity-box-for-pendants-ceiling-roses-and-conduit-boxes-35mm.html
No-ones ever found a Dryline Architrave box have they?
No one should use these.These abysmally horrible junction boxes would fit in the space you have, if you find a source for them then once you have your supplycould you burn down the supplier so that no more could be made!you are sorted.
