Guest viewing is limited
I2C
https://i.Upload the image directly to the thread.com/gAO3TXS.png
I've been doing a bit of research on the standard British 3-pin plug under BS1363 as I would like to know exactly what is/isn't compliant so I can advise customers if I spot an appliance using a substandard plug.
I know there are basic and well-known considerations such as:- live pins must be partially-insulated, earth pin must be solid (brass for class 1 / plastic for class 2, etc); appropriately fused on the line conductor, earth-pin longer than live-pins to make prior-connection for safety and to open shutters for live pins; just to name a few.
I've been trying to find a PDF copy of the BS1363 regulations as a reliable and comprehensive source of information, however so far I've only managed to find guides such as the "IET 2013-49 Winter Wiring Matters" - which is great but lacks a lot of information that it makes reference to throughout it's content (such as dimensions, degree of insulation, materials, etc).
The BSI shop sells an official copy of the regulations at a price of £234.00 for non-members (£117.00 for members) which seems incredibly expensive; I'd be happy to buy it if I were a manufacturer (just like us electricians buy a copy of BS7671 despite the price) but I'm only inquisitive. Is there a way to legally obtain a PDF copy for free? Or at least a comprehensive guide from a reliable source?
I appreciate your help in advance.
- Chris
If you put BS1363 into a search engine such as Google, you should find plenty of websites with pictures of dodgy plugs, including BS 1363 Plugs and Sockets - http://www.bs1363.org.uk/.
If you have a suspect plug that looks generally OK, you can put the ASTA or kitemark number into ASTA BEAB - Welcome to the BEAB Buyers' Guide. - http://www.astabeab.co.uk/buyers-by-number.asp
BS1363 can be viewed at many main libraries.
Thank you for your help M-Ty!
I had a look on the website www.bs1363.org.uk which is great, but I'd love to see the BS1363 standards for myself (even though raw-standards are usually long, boring, complexly-worded) but it would be ideal to take notes from.
The library is a good shout, I'll check the city library (more comprehensive than my local) to see if they have a copy. It would be fantastic to get a PDF though.
The Newcastle way in to BS has closed down. probably because too many registered.
As above BSI are very protective of their documents, it's unusual to find a PDF online .
You may be allowed a photocopy in a Library.
Assesing quality of connected cable became problemetic,
once it could hide in a moulded plug -both ends, with
vibration proof crimped joints !
( Measure , rather than visual . )
Any magnetic steel has to be a bad clue .
"JWard" videos are good where he persecutes copper coated Aluminium cables !
ESC did produce a plug checker which is a very handy piece of kit to have in your wallet. All the links on their website seem to be dead but this is what it is.
Hi - if you want a PDF of the standard you will have to pay for it I'm afraid.
It seems that all the legitimate PDFs are paid-for, at a expensive price too! Thank you for the link Wilko, I'll check it out.
It does seem that they are keen to charge for their documents, it's just a shame it's so much money. Like you say, I think the library is the best idea. Thank you for your help snowhead.
I haven't seen his video on this actually (I have watched a fair few, good content!) so I'll take a look. Moulded plugs seem like a great idea when everything is in order. Like you say, it can be problematic. Cheers static zap.
Hi,
Hint, have a look at the size maters link on this page, it gives the expected sizes of the pics.
I'll take a look, thank you for the hint UKMeterman.
That looks fantastic, I've never seen one before. You'd think these would be more popular than ever with certain auction-sites. Thank you Strima!
I2C
East Sussex
British Plugs / Sockets Regulations (BS1363)
I2C,
I2C,
