R
rolyberkin
I have an old Metrel which is fine but would really like an MFT which can do continuity without having to keep pressing test and also has a memory and earth rod test built in, what are your best suggestions, or what do use and why do you like it?
I have the Megger MFT 1731... it has a memory (don't ask me how to use it as I don't), it has the capability for earth rod testing and will do continuity by simply connecting it to the circuit/item under test.
I like it. It's nice and quick to use and doesn't have lots of sub-menus like the Flukes.
Personally, I'd look to see if you can have a go with whatever you are looking to buy. I tried a Fluke and Megger and opted for the Megger because it was just nice and simple to use.
I was on 2391 course today and saw someone using a Megger which has prompted me to change mine, looked good.
The new MFT1741 is fully specced with new loop test technology, repeatable tests for greater confidence in the readings. I'll stand corrected as have only read the overview quickly, but I believe it does the full suite of electrode tests that previously were only on the 1735, although the long leads and spikes have to be bought separately. Test Meter had a discount code for it, there's a sticky on the forum, although that may have only been for October.
The higher spec 1700/1800 Meggers,are up to job,and,in my opinion,are instinctively easy to use,and to therefore have confidence,in.
If you can grab a test,from either a dealer,or fellow spark,you may determine if it suits.
Had a Fluke 1653B was very good but NICEIC assessor said try the Megger and I used to have a company 1553 Megger and my 1731 MFT is out of this world.
My new 1731 does all the rod tests the same plus all new loops and also stakeless art rod tests etc.. or get optional clamp for rod tests too.
What are "new loops".
Brekkie time at mine, so this might be it ?
