I
I2C
Hi Guys!
I've worked with a few qualified-electricians recently and I'm shocked with the large-scale misconceptions regarding the proper safe-isolation procedure, particularly concerning the function of an AVI (Approved Voltage Indicator).
During the last few weeks I've met several domestic qualified-electricians who have told me not to test between line-earth & neutral-earth because this will trip the RCD/RCBO; they have all advised me to only test between line-neutral. When I confronted them with actual facts and figures, they all refused to acknowledge my comments, arguing otherwise without any form of proof, which I found bizarre?
I'd like to confirm that their advice is incorrect, and I can prove it factually. I use a Kewtech KT1790 Approved Voltage Indicator which seems fairly common amongst electricians, and I'll base my comments on this:
I'm interested to find out if anyone else has encountered this problem? If so, to share this information.
- The Kewtech KT1790 data-sheet states "This instrument can make measurements between L-PE without tripping RCDs".
- The Kewtech KT1790 data-sheet states that the devices internal-resistance is 200,000 Ohms. Based on this value, we can calculate the current-flow using basic Ohm's Law:
- 230V - 1.15 mA (Standard RMS voltage used for design calculation)
- 245V - 1.22 mA (Highest likely RMS voltage measured)
- 500V - 2.50 mA (Exceeding AC Peak Voltage)
- A common RCD used in domestic properties for additional-protection has an operating-current of 30mA (much greater than the current produced while testing).
- Rarely in specialised circumstances a 10mA RCD is used for certain applications (much greater than the current produced while testing).
