Should not have failed due to lack of RCD protection.
Flat was converted in 2003, no requirement at that time for RCD protection, other than for sockets which could reasonably be expected to supply portable equipment outdoors.
Never mind anyone getting "called out" the point in question was the safety of the landlords Tenants. Would you be happy if one of your family was living in a rental with no RCD protection? I will assume a "no" to that one, you can always take another view of course.
I would be perfectly happy for any member of my family to live in a flat above ground level without RCD protection. Presumably all flats were electrical death traps until the fairly recent introduction of blanket RCD coverage? I don't think so.
And the ones installed in the 1970's and 1980's didn't catch fire either ........... it was the onset of plastic enclosures and more importantly dam right flimsy main switches, MCB's and neutral bars that caused all the problems...
But you wouldn't be even happier if it did ?
Peterpipe,
DPG,
