S
Steve_bcs
I'm planning to install a U-Heat mat in a small en-suite. Never done one before. The thermostat will be on the adjacent bedroom wall. What is the recommended method of providing the live feed to the thermostat/on off switch unit? From a fused connection unit, switched fused connection unit or a spur off a nearby ring socket? The walls are studs and not yet plasterboarded in the en-suite. The ring is RCD protected at the Consumer Unit. tia
spur off rfc. fit a double pole SFCU so that in the event of a fault in the ufh, both poles can be isolated locally.
underfloor heating is notifiable irrespective of whether it's in a bathroom or not.
Steve_bcs,
Octopus,
