Steve_bcs
I'm planning to install a U-Heat mat in a small en-suite. Never done one before. The thermostat will be on the adjacent bedroom wall. What is the recommended method of providing the live feed to the thermostat/on off switch unit? From a fused connection unit, switched fused connection unit or a spur off a nearby ring socket? The walls are studs and not yet plasterboarded in the en-suite. The ring is RCD protected at the Consumer Unit. tia
