but OP will need to go back and make sure plumber has put all the right wires in all the right holes, with no twisted and taped joints into bell wire, then test and issue a MWC.As others have said, go there and prove what's wrong - if it is the element that's a job for a plumber!
and of course not mention to customer that the old tank you charged him £40 to dispose of environmentally friendly, got you £30 from the local scrap yard.Don't like those immersion jobs, so I am biased...but being so, I would just tell 'em to get a plumber in. Wouldn't go out to look at it just to say the same thing. The older cylinders were thicker, I think, so could stand more spannering, but a buckled, leaking cylinder on a Saturday night is a nightmare.
Of course, were I a plumber, I would upsell to a different system! LOL!
If I had to go near a hammer I’d consider it a plumber job.i always found that gently tapping the spanner rapidly with a 4lb. lump hammer released it without the tank failing.
Happily dispose of the old one though.
all depends on your definition of waste:
Waste (or wastes) are unwanted or unusable materials. Waste is any substance which is discarded after primary use, or is worthless, defective and of no use.
a copper tank is, by definition , not waste, as it will be recycled, and as such is not worthless, defective, and of no use. same applies to scrap cable.
