Pot noodle, because I get hungry sometimes.
Are you still only the tea maker?
Oh yes, and a kettle.
he's not from essex.so he no need all that crap.So how do you carry all this? View attachment 44608
Oracle, I assume you are asking the question ISITEE specific as it is in this sub forum.
Apart from the obvious things, this will vary depending on what industries you test within. For example, we do most of our ISITEE within the entertainment industry and have a large collection of different short jumpers and mounded adaptors for the various connectors and inlets that we see regularly, but you may never see if just doing offices.
An isolation transformer for testing of plugtop type RCDs is a useful addition for anyone doing ISITEE regularly.
9 screwdrivers, hammer, 3 files, 2 slip joint pliers, 2 adjustable wrenches, standard pliers, needle nose pliers, ratchet crimper, spirit level, chalk line, draw tape, 5 spanner’s, center punch, a couple of podgers, set square, measuring tape, standard hack saw, juinior hack saw, cable cropper, side cutters, some drill bits, various crimps, some long 3.5mm screws, marker pens, volt stick, couple of pencils, pencil sharpener, some screw driver bits, an old paint brush, various hole saws, pad saw, then whatever else you might need for specific jobs.
