B
Baddegg
Fitted 9.5 kw aquas aquamax shower today (customer supplied) and new full rcbo consumer unit, all good except the shower is absolute s£&t! Even on the highest setting the water is only moderately hot, water pressure seems fine and no different to any other showers I’ve fitted, one thing I did notice was when I clamped the meter tails with the shower running on full heat it only ever pulls approximately 15amps,new 10mm cable run in void under the floor for approx 18mtrs to a chase in the wall upto isolation switch with pvc wall panels over that,plenty of free air around the cable,admittedly I’ve never had to clamp a shower before but does that seems low for a 9.5kw shower?
Thanks as always
Thanks Suffolk,that’s my plan tomorrow ha ha just want to make sure I havnt missed anything, I can see it becoming --- for tat with the manufacturers....
Some shower have dip switches on the PCB where you can un limit the temp of the shower.
Also just a tip for showers, most of you already know but always purge the shower before using it just to make sure the water pressure is what it should be if the water has been off.
Although as Tel says 35-37 amps on top setting shohld be what your getting.
Thanks spoon, yes checked the circuit all fine, as I say it’s all new and all readings are good,just like to cover my arse ya know :)
Check water pressure.
I fitted a customer supplied shower that he took water from cold bath tap.... was tank fed, less than a bar pressure. The shower just cut out when trying to run.
He had to get a plumber to tap into the mains pipe feeding the tank.
It’ll tell you in the installation manual if it’s mains only.
Connected to mains Chris..did the jug test and gets about 1.3 bar,manufacturers state between 1 and 1.5 is fine anything above is good
